3020 jd needs help
tracy
10-06-2002 09:09:31
what other engines fit in a3020 jd minehas blown
Joe C.
10-07-2002 10:57:02
 Re: 3020 jd needs help in reply to tracy , 10-06-2002 09:09:31
I have seen a couple of 3020 rear ends attached to a front end from a 4010... i am told its not too hard of a job as long as both halves are in good condition
G-MAN
10-06-2002 11:04:55
If you're talking about other engines that will just bolt in, you're not going to find any others that will fit right in your 3020. If you're talking about a repower type situation, I've seen other Deere engines and Cummins "B" series engines that were modified to fit. Be forewarned that it will probably be cheaper and easier to rebuild your engine or find a good used engine to install in your tractor. What do you mean by your engine being "blown"? Did it have a major failure such as a thrown rod or broken crank, or is it just worn out?
tracy
10-06-2002 15:23:53
 Re: Re: 3020 jd needs help in reply to G-MAN, 10-06-2002 11:04:55
3020 JD messed up crank shaft and balancer box.
John in Md.
10-06-2002 17:27:14
 Re: Re: Re: 3020 jd needs help in reply to tracy, 10-06-2002 15:23:53
If you go with used parts,you shouldn't have a problem finding a decent crank.But that harmonic balancer is about impossible to find used for a side console,there are a few for old style but still hard to find.
Still it's cheaper to rebuild than repower or buying a used engine of questionable origin.
We did a 72 diesel and got the crank reground for $400,bearings were about $190,and used balancer was around $465.That was last year.Shouldn't have gone up to much.
