Hydraulic Pump
Ernie
10-05-2002 19:48:06
I have a 1520 JD and the hydraulic pump makes a noise a low rpm's is this normal? Thank you
Charlie
10-07-2002 05:44:20
 Re: Hydraulic Pump in reply to Ernie, 10-05-2002 19:48:06
I also have a JD 1520 but my hydraulic pump makes noise when I start to use it, like raising the loader or turning the steering wheel. It seems to be fairly quiet while under load or setting in idle but makes a noise when I start to doing something with it. I've been trying to find out if this was normal but haven't found anyone with a 1520 that does the same thing. I believe that these are the same pumps used in the 2020 but I haven't gotten any feed back that any noise is normal.
In your case are you sure that your system is completely closed so that no fluid is leading through a valve? As an experiment you might try plugging the pump's output to see if you still have the noise at lower rpm's.
I'll be interested to hear about any fixes you find for your pump.
Thanks,
Charlie
