Is it possible to put a rockshaft on a 70 standard?
Lester
10-05-2002 19:17:02
Wondering if it is possible to take a salvaged rowcrop 70 that has a rockshaft and put the rockshaft system on a 70 standard? Dont know if everything would work out right? WOuld like to have a 3 pt on a std. I've seem some standrads with rockshafts, but most are without. Dont know if they used the same setup as a rowcrop? Any help would be appreciated. Thanks.
JDGnut
10-07-2002 07:03:57
 Re: Is it possible to put a rockshaft on a 70 standard? in reply to Lester, 10-05-2002 19:17:02
Yes, the 70 standards were available with the powerlift/rockshaft.. Mine has an 801 hitch on it.. The aftermarket 3pts will also fit on the 70 standards once the lift is installed.. Good luck.
JDGnut
JD70
10-06-2002 20:07:57
Not only will you have to add rockshaft,but will have to add powr trol pump and lines.
G-MAN
10-07-2002 05:26:34
 Re: Re: Is it possible to put a rockshaft on a 70 standard? in reply to JD70, 10-06-2002 20:07:57
If I'm reading the parts book right, and I didn't look all that close, it looks like some of the 70s were available with a power-trol pump and set-up to run a cylinder, but less a rockshaft. I don't know how common those are, but it is shown in the parts book. Probably built for the guys that used hydraulic cylinders on equipment, but had no use for a rockshaft, as in a wheatland type situation.
G-MAN
10-06-2002 13:47:00
Lester, in the parts books for the "70" and "70 Diesel", they only show one rockshaft housing - an AF1660R, so I presume that it fit both the standard and row-crop versions of the "70" tractors. If you take the rockshaft off of a donor tractor, just make sure you get all of the related parts to make the installation easier. A parts book would be a big help, also, to make sure you have what you need.
