49G battery's?
Will P
10-04-2002 22:24:01
Will be picking up a "needs some work" 49G on Saturday. It will be my first electric start tractor. My other 2 are hand starts. It has no battery's in it. Is it two 6 volts wired in series or parallel? If the total voltage is 12, can I use just a 12 volt battery? It still has a generator on it. It has a mag and lights. No distributor. Thanks for the help.
Will P
Mike3
10-06-2002 08:43:40
 Re: 49G battery's? in reply to Will P, 10-04-2002 22:24:01
I just use one big 12v battery in my GH it works fine, but it is a show tractor and don't run it in cold weather.since the tractor has a high compression head it turns over hard, but one 12v does the job.
Bubba
10-04-2002 23:01:40
We just started on a '50 "G" this week, and installed a good high amp size 65 battery. Works really well. Back when they built your "G", they used two six volt batteries 'cause they didn't have any twelve volt worth anything.
