JD G Generator Number
John in OH
10-04-2002 18:40:07
The JD parts manual (PC369, pg 110-111)for the Model G lists two generator part numbers -- for S/N 13000-25999, the generator is an AA4921R, Delco-Remy 1101755; for S/N 26000 up, the generator is also an AA4921R, Delco-Remy 1101777. Does anyone know the difference between these two generators? Are they interchangable?? TIA, John
Clooney
10-05-2002 05:13:42
 Re: JD G Generator Number in reply to John in OH, 10-04-2002 18:40:07
John, the info is kind of sparse but a quick look shows he 755 probably used a cut-out relay & the 777 probably used a regulator. The case screws & pulleys are the same so the length is probably the same & they are both 3 brush generators. ~They are both 12 volt generators & both use close to the same field current [755=1.6 amp & 777=1.6-1.69 amp]. The 755 puts out 6-8 amps @ 2200 rpm & the 777 puts out 6-8 amps @ 2000 rpm.
~I would think they would interchange without a problem but without actually comparing them side by side I can't say for absolutely sure.
John in OH
10-06-2002 08:23:31
 Re: Re: JD G Generator Number in reply to Clooney, 10-05-2002 05:13:42
Thanks, Clooney. Good information!
