JD300 industrial 3 point
carl
10-04-2002 16:49:23
We have a JD300 that performs great but the 3 point is very touchy. Two inches of travel on the control totally lifts or lowers the scraper box. This tractor sat for years and has had several hydraulic oil changes[the oil always is milky] and everything else works great. Ideas?
Jim B
10-05-2002 04:44:31
 Re: JD300 industrial 3 point in reply to carl, 10-04-2002 16:49:23
Carl,milky oil can be caused by rain water entering trans. around shifter boots also check hyd. filler cap as it has a breather hole that could be stopped up not letting condensation out.Roockshaft valves have an adjustment for clearance under seat on right side accessed by removing a plug.I think ind. and ag. are same so check load & depth control setting,be sure it is in D.Jim B
