AR oil line question
MikeH-Tx
10-04-2002 15:17:48
An AR parts manual is on the way, but I have a question that some of you can surely answer:
When I was disconnecting oil lines inside the crankcase so I could remove the crankshaft, one line came out in pieces (not good, I suppose). It used to be connected to the governor and was next to the oil guage line. The other end looks to be an open pipe that doesn't connect to anything, but rides near the sump bottom.
What is this?
Cal
10-04-2002 22:40:22
 Re: AR oil line question in reply to MikeH-Tx, 10-04-2002 15:17:48
l just happen to have my AR apart. The oil line from the governor and guage feed go to the oil filter housing next to the main line coming from the oil pump. The filter housing has two more lines coming off it, one from each side feeding the main and rod bearings. My AR is a 260000 and up, so I'm not sure if the oil lines are different for the early ones. Hope this helps.
