De-Polorizing a Mag, Possible ????
Darren
10-04-2002 00:01:09
Unstyled G. Mag was working fine. Used the tractor for a ground for a patato luancher, The mag lost all fire after that.We used a plunger ignitor off a bbr grill for a firing device and grounded it to the front steering assembly with a small aligator clip and some wire. Would this have possible been the cause of the mag failure. I have heard of magnetos on old autos depolorizing, but from different causes. Any thoughts ?? Thanks in Advance
Clooney
10-04-2002 03:10:36
 Re: De-Polorizing a Mag, Possible ???? in reply to Darren, 10-04-2002 00:01:09
Darren, it's possible but probably unlikely.
~I have welded on many tractors that have mags & created a much bigger magnetic field than your grill igniter without any repercussions.
~If the tractor was/is stored outside I would suspect water or condensation in the mag.
~What make & model mag are you working with? See if the mag has any condensation in it & if it has moisture or rust in it. If so clean that & clean or replace the points/condenser then see if you have spark.
~If you have a Wico mag you can send the mag rotor to Roberts Carb to have the rotor re-magnetized for little money & a fairly quick turn around. If you send the whole mag it will take much longer...
Darren
10-04-2002 14:59:19
 Re: Re: De-Polorizing a Mag, Possible ???? in reply to Clooney, 10-04-2002 03:10:36
it is indeed a wico clooney, thanks for the help, ill proably just tear it apart and follow your advice and if worse comes to worse ill send it out to to be repaired. thanks agin
Darren
10-04-2002 14:59:18
