2510 THREE POINT HITCH
John in Md.
12-24-2003 12:17:58
Is a 2510 supposed to have Catagory 1 or Catagory 2 hitch? I thought they were three plow tractors so I would assume Catagory 2.
I just saw one with Catagory 1 lift arms and the top link had a smaller pin attachment to tractor and a Catagory 1 ball. It appears to be factory not aftermarket.
Had never seen one optioned like this one, is it odd or just another option.
Glen in TX
12-24-2003 21:48:24
 Re: 2510 THREE POINT HITCH in reply to John in Md. , 12-24-2003 12:17:58
The 2510 and several other new generation tractors had reversible sway blocks to change from Cat. 1 to Cat. 2 or Cat.2 to Cat. 3. We would sometimes change the sway blocks on a 2510 we had from Cat. 2 to Cat. 1 and use the bushings to mount different things on it. Owners manuals for these tractors explains this.
John in Md.
12-25-2003 09:33:48
 Re: Re: 2510 THREE POINT HITCH in reply to Glen in TX, 12-24-2003 21:48:24
The lift arms have catagory 1 size holes, not 2 and use bushings.As I stated lift links are catagory 1, and the attatching bracket on the trans cover is catagory 1 for a top link that has catagory 1 hole in it. Doesn't show in parts book, only hi crop has catagory 1 lift arms. Any ideas?
John51
12-24-2003 18:12:43
My 2520 has a cat 2 hitch same as the 3020. I always figured the 2510 and 2520 were the same hitch.
T213R
12-24-2003 20:33:01
 Re: Re: 2510 THREE POINT HITCH in reply to John51, 12-24-2003 18:12:43
Does it have the adjustable, two position sway blocks? I always understood that the 2510 had the same 3ph parts as the 3020. The 3020 had sway blocks which , depending on how mounted would space the lower draft arms for either cat 1 or cat 2. With cat 1, you also needed the bushings because of the smaller diameter attaching points.
John in Md.
12-25-2003 14:44:25
 Re: Re: Re: 2510 THREE POINT HITCH in reply to T213R, 12-24-2003 20:33:01
The sway blocks art reversible but the odd thing is the hitch is catagory 1 on a catagory 2 tractor.
