70 power steering
Robert Ostmo
10-03-2002 07:48:20
Clooney,
I've since done a little more work on the PS on my 70. I had the steering control valve housing
off, cleaned it all up in solvent, and made sure
the arm was aligned with the groove in the shaft
upon reinstallation. It didn't change. Still turns all the way to the right. Next, I bought a short fan belt, and bypassed the pump, driving just the generator from the fan pulley. The steering still turns all the way right on startup
and cannot be centered until shutdown. Obviously
the PS pump is not driving it to the right. It
did not do this before I put PS fluid in the system, just steered normally without power steering. Does this suggest more the location
of the problem? Thanks.
Bob seND
ps I have done no adjusting to the cams as is was
set OK before disassembly.
Clooney
10-04-2002 03:43:33
 Re: 70 power steering in reply to Robert Ostmo, 10-03-2002 07:48:20
Bob, as Frank said the pump was still turning.
~I still believe your problem is in the control valve [or sleeve control of the valve]. If that valve is operating correctly & adjusted properly there is no oil flowing to the steering vanes in the pedestal until you turn the steering wheel.
~Have you loosened the holding bolts & slid that valve all the way forward & rearward to see if that will change the problem? Is the gasket between the valve & housing intact & not allowing oil to get into the wrong port? Is the valve worn, chipped or not tight to the fork?
~Remove the valve & use an air blow gun to direct air pressure into the pressure port then slide the valve forward & rearward to see if it is shutting the flow off to the closed port & directing the air to the open port.
~If the valve is operating properly then about all that is left is the sleeve, sleeve pin/screw, or cam, or maybe even worn worm bearings. If the valve is working correctly something in the sleeve area is not allowing the valve to return to center with the steering wheel in the center position��..
F-I-T
10-03-2002 08:08:27
Robert:
The pump for the power steering is directly driven by the fanshaft. The pump pulley you skipped over by using a short generator belt was the water pump.
The power steering unit is still getting hydraulic power as long as the engine (and fan) is turning.
Frank-in-Tallahassee
70D // 855
