4440 Charging problems
buckaroo
12-24-2003 11:13:58
Just bought a JD 4440 which runs great, but the wiring is BAD.. Will not charge battery. Alternator is new and checks out ok. In circuit, with engine running it only puts out 12.5 volts. When lights are turned on, shows a discharge. Ammeter is the only gauge that works! Help. Is the voltage regulator in the alternator? what is that funny looking fuseblock near the console?
Where do I start? thanks.
david val
12-24-2003 12:08:11
 Re: 4440 Charging problems in reply to buckaroo, 12-24-2003 11:13:58
in systems with a charge control light, the voltage from the light excites the alternator to start charging. in the 4440 there is a voltmeter for monitoring charge, so instead of a light there is a resistance wire connected to the alternator #'1' terminal. with the key switch off and control plug disconnected, a test light should glow on on the wire connected to #'2' terminal, and show no voltage on the other wire (the resistance wire). with the key swith on #'2' should glow brightly with system voltage, #'1' shouls have reduced voltage an the test light should be dimmer.
if there is no voltage on #'1' wire, the resistance wire (which is a single steel like wire) is probably broken. try to pull the end of this wire. if it's broken close to its end the broken piece will be pulled out. you can strip the insulation to that point and test again. if you have voltage and didn't loose more then 4 to 5 inches you can reconnect the wire to the alternator (that's beyond the few inches of regular wire at the connector)
if there is no voltage you can get a resistance wire kit from deere or use a diode with regular wire istead of the resistance wire.
if i remember well the latest 4440 already came with a diode. i also think that the original kit also incorporates a diode.
david
buckaroo
12-24-2003 13:54:54
 Re: Re: 4440 Charging problems in reply to david val, 12-24-2003 12:08:11
david, Then this setup must not be original. There is one lead coming from the dash (power in) that goes to the connector on the alternator. Then a lead exits the alternator to I guess terminal one (the one not color-coded red). Then there is a large gauge lead from the red terminal to the solenoid/starter area. There are no other components that I see associated with it. thanks. buckaroo
david val
12-24-2003 15:10:19
 Re: Re: Re: 4440 Charging problems in reply to buckaroo, 12-24-2003 13:54:54
i assume the alternator is delco remy or nippondenso similar to the original. there should be two male flat connections which are part of the regulator, (originally on top) and one power output screw connector. to the power output there is a thick red cable that should end at the starter relay which is the (+) junction point. a thinner red wire originally comes from the same junction back to the #'2' male at the regulator. sometimes, when there are troubles with the harness, a wire can be connected directly from the D+ (power output) to #'2' terminal. the third wire comes from the bulkhead multy connector to the #'1' terminal on the regulator (if on top of the alternator-the left one as seen from the seat). this one should have reduced voltage when key swich is on. if i remember well it's color is brown/white. this is the resistance wire.
if all wires are connected correctly and have voltage as described in my preveous post, and there is still no charge, there is probably a problem with the alternator.
btw, if the wires are crossed at the regulator, the batteries will discharge in a few hours with the engine off.
david
buckaroo
12-25-2003 09:55:40
 Re: Re: Re: Re: 4440 Charging problems in reply to david val, 12-24-2003 15:10:19
David, Your info should get me going. I will go out to the ranch and see if I can debug it. I'll let you know the results. Thanks a lot for your help. Mitch
