JD 2010 gas Utility Industrial tractor
Bill
12-24-2003 10:43:09
Looking for a rear tire hub for a 60's tractor part number T15351T. That is the number stamped on the hub. I know it has to come from a salvage yard. If you can help me, please email. Thank you. Bill
jdemaris
12-24-2003 18:26:49
 Re: JD 2010 gas Utility Industrial tractor in reply to Bill, 12-24-2003 10:43:09
You can try Link He had some last time I was there. In Central New York State. He's not cheap, though - and sometimes doesn't know what he has in his own scrapyard. I assume you've got a splined hub that's worked loose on the axle? When I worked for a Deere dealer 30 years ago, we were having trouble with them and Deere was selling kits to glue them together. Kit was an industrial strength epoxy made by Devcon. We used it on the 2010s along with the 440 and 540 log skidders. Actually worked pretty good if there were enough splines left.
Bill
12-25-2003 02:23:10
 Re: Re: JD 2010 gas Utility Industrial tractor in reply to jdemaris, 12-24-2003 18:26:49
Your are corrected on the square spline. This did work loose, but unable to repair. I have tried alot of places to find the part and appreciate the lead.
