John Deere 4000
Royce
10-02-2002 07:21:40
Saw one of these in the Photo Gallery and at a tractor show. I've never seen one before. Looks like a 4020. What's the difference?
TB SCOTT
10-03-2002 09:15:01
 Re: John Deere 4000 in reply to Royce , 10-02-2002 07:21:40
Deere needed to come up with something to be at the 100 horse range yet be priced to compare with farmall. Deere was loosing alot of sales because of the price of 4020's were alot higher than same horsepower farmalls....:-)
JD70Jim
10-03-2002 11:54:02
 Re: Re: John Deere 4000 in reply to TB SCOTT, 10-03-2002 09:15:01
Actually, it was the 76 hp 756 which was agravating John Deere. They really needed an 80-85 hp tractor to fit in half way between the 71 hp 3020 and the 95 hp 4020. The 4270 engine couldn't be reliably stretched to 80 hp, and the available 6329 (Dubuque built) engine cost more than the 6404 engine in the 4020. The intermendiate tractor HAd to cost less than the 4020. Tather than reintroduce the 6380 engine from the 4010 (would have been perfect) they simply put out a cheap version of the 4020. The 4000 was WAY more tractor than a 756 or even a 766. Unfortunately, many farmers pretended that their new 4000 was really a 4020 and used it with 4020 sized loads, even turbocharging them and using them with 4520 sized loads. This didn't work too well, so when it came to be model replacement time at Deere, the 80 hp 4030 had the 6329 engine instead of the 6404 and the lightwight, high horsepower(for it's time) 4000 was not replaced, and the 3020 size was given the six cylinder and designated 4030.
Ty
10-03-2002 06:33:41
My neighbor has one at it was there favorite tractor. I got to use it once. It is different compared to our 4020 but power wise it's right up there. Seeing that full gauge needle like on my 70D that gives you the speed also at that rpm. I like that so you don't have to turn the dial to find it will driving. I also know someone w/ a 3010 and compared to our 3020 the 10 is economical just because of the dash goodies etc.
leon
10-02-2002 16:16:47
In an attempt to lower selling price and manufacturing cost, some of the bells and whistles were stripped off the 4020, and it was called the 4000. Insite the company it was commonly called the "forty nuthin"!
Jim B
10-02-2002 12:36:56
Royce,4000's were a cheaper 4020,one light in fender instead of two,no cowling covering rockshaft,and only came I think with syncrorange transmisson.I don't remember that trans. and diff. were lighter but alot of water has run under the bridge since I sold them.Jim B
JD70Jim
10-02-2002 16:08:42
 Re: Re: John Deere 4000 in reply to Jim B, 10-02-2002 12:36:56
The later 4000s did come with powershift. You could also get them in gas. Most of the 4020 options were eventually made available for the 4000. The SN code for the 4000 begins with a "B". as in "B213R 231000 R". They are getting to be very collectable also!
WTW
10-02-2002 15:10:19
Royce, As previously and incorrectly stated many times before, the 4000 did not have a 3020 power train. The 4000 tractor has the same transmission and differential as the late model 4020 with the exception of the reverse synchronizer. The only thing different in the power train that made the rear end lighter was the rear wheel centers and the final drive units. Final drives and axles were unique to the 4000 tractor and was not a 3020 part what so ever. The 4000 did share the same three point arms and axle shaft (diameter) as the 3020. A 4000 / 4020 parts book will show these parts. It was not in any way a 3020 transmission / rear end, as allot of people seem to think it is.
JD 4000
10-02-2002 11:58:36
third party image
Yeah G-man, Royce.. just like what G man said. and I have got a 71 JD 4000 here too. am't selling it! it's just like the 4020..
G-MAN
10-02-2002 07:45:45
Royce, according to what I've read, the 4000 was Deere's attempt split the difference between the 4020 and the 3020. It had about the same horsepower as a 4020, but used a little lighter duty transmission and rear-end. It was built so that guys that wanted to move up from their 3020, but didn't want to replace all their equipment, could move up to the six cylinder tractor. The 4000 was designed to pull 3020 type equipment at higher speeds, and come close to the productivity of the 4020 with less capital outlay. That probably isn't the most technically accurate description, but it will give you a general idea of the plan behind the 4000.
