JD 3300 combine motor, good for anything else
Eric Hoying
10-01-2002 12:29:56
Hi all, first time post for this board. Have a question, I have a JD 3300 combine with a good motor (gas), but the rest is shot. Can this motor be used for anything else, such as a tractor.
Thanks for all input.
Eric
MIKE HANLEY
10-01-2002 20:30:04
 Re: JD 3300 combine motor, good for anything else in reply to Eric Hoying, 10-01-2002 12:29:56
I get FARM SHOW P.O. BOX 1029 Lakeville Minn. 55044 (ph 612 469 5572.
Its alot like this board. No adds. Just farmer articals,, BEST I RECOMMEND IT.
There has been articals in there about guys that take old worn out combines, and strip them down to the cab, frame, and motor and then mount a loader, or a snowblower. One guy mounted a tool bar and uses it as a self propleded corn planter.
Brian
10-01-2002 18:18:37
Do you have a combine demolition derby at your local county fair? We have one coming up next week in Central Ohio that is usually pretty good! I think there are going to be 18 combines in it this year and 5 more people decided not to enter. That would be a fun use for an otherwise useless machine. I missed my chance to pick up a combine in field ready condition this spring at out tractor club's annual consignment sale for $500. It would have made a great demo derby toy after using it a little to justify the purchase. What ever you decide to do, good luck!
Brian
Gary
10-01-2002 22:10:17
 Re: Re: JD 3300 combine motor, good for anything else in reply to Brian, 10-01-2002 18:18:37
Sounds like a sad way for a machine to die too me. They could be restored or have parts sold to work on other machines. I know we can't restore all of them but its just sad when you stop and think about those of us who are wanting to get some old machines and are haveing some difficult times to hear about these events.
Mr. Thinker
10-01-2002 15:36:16
Yes, it can!! The 4-cylinder 202 engine in your 3300 would be a good replacement engine for a 2020, 2030, or JD 400 tractor with a gasoline engine, and would also fit in 2510 or 2520 gasoline tractors. Probably some other machines, too, but these are what come to mind.
JD70Jim
10-01-2002 13:38:35
My copy of Hotline says it's a 219cid 6cyl in either gas or diesel. If they are correct, and you have a SIX cylinder engine, it isn't used in ANY tractors that I am aware of. The 2510, 2520, 2030, 2440 used a FOUR cylinder engine. You could certainly try and shoehorn this 57(E) hp engine into something if you wanted to, but as it's a GAS engine, why bother? Perhaps you could install it in an old S10 or Ranger pickup truck and go for "different"!
Doug in IL.
10-02-2002 07:06:22
 Re: Re: JD 3300 combine motor, good for anything else in reply to JD70Jim, 10-01-2002 13:38:35
Hotline is wrong in this case, and in a lot of others too! The 3300 has a 4 cylinder in either the gas or diesel versions.
Ralph
10-01-2002 13:12:13
Not sure what, but used in 2510 or 20??, 2440?. Do you have bin extensions or rear wheel weights? Also size and condition of tires?
