35 Clutch slip to Clooney
marty Z
09-30-2002 22:13:56
Thanks,
I pulled the clutch assembly tonight and found greese all over the place from the pulley bearing. The felt washer /gasket is hard as a rock, and again it was a shortcut that I failed to do right the first time. I am ordering a new one , and I hope that fixes it. the dogs and pins still look good. If this doesn't work I will be back again.
Thanks
Marty Z
Curtice Ohio
Clooney
10-01-2002 03:10:51
 Re: 35 Clutch slip to Clooney in reply to marty Z, 09-30-2002 22:13:56
Marty, make sure the oil drain back holes are open also. If the oil can't escape it will end up in the clutch area of the pulley.
