3pt for my jd 60 or 70
vern
09-30-2002 14:02:03
i would like to put a 3 pt. on the back of my 60 or 70 john deere, to run a blade for my driveway. does this work well and can i get a new or used one at a fair price. thanks for you input.
Andy Carstensen
09-30-2002 19:16:51
 Re: 3pt for my jd 60 or 70 in reply to vern, 09-30-2002 14:02:03
Trust me unless you are just wanting a original JD60 go with the after market hitch like the saginaw. I have an 801 hitch on mine and the after market one will be less hassle.
Ryan M
09-30-2002 15:35:32
I own a 3-point made by saginaw county tractor and just as Clooney says, they are very nice. The center attaches at both the axle and the drawbar. The Center is made out of 3/8" and the lift arms are 1/2". It comes with stabalizer arms and the dual Catagory 1 and 2 Balls in the end. Well worth the money. Have one on both My A and B
Clooney
09-30-2002 14:15:50
Vern, an aftermarket 3 point will work great on either the 60 or 70. ~While there are quite a few aftermarket 3 points out there about the best I have found is made by "Saginaw County Tractor Parts" [see link below].
~If using for blade work or snow removal the 60 will probably work better as the 70 has very fast gears in it & going slow isn't one of it's strong suits.....
here's the link
09-30-2002 14:17:57
 Re: Re: 3pt for my jd 60 or 70 in reply to Clooney, 09-30-2002 14:15:50
The link didn't post, so here it is.....
dl
09-30-2002 14:15:08
Saginaw seems to have a good hitch. Try the following website:
http://www.saginawcountytractor.com/
