JD 50 brake question
Bruce L
10-18-2003 08:02:07
third party image
My JD 50 brake housings have oilers but they seem to be redundant because solid bushings are installed. The solid bushings do not let any oil through to the shaft from the oiler. The shaft and the bushing seem to be in good condition. Are these oilers vestigial remnants from an earlier design or are they really supposed to be functional?
F-I-T
10-18-2003 09:56:23
 Re: JD 50 brake question in reply to Bruce L, 10-18-2003 08:02:07
Bruce:
I believe the outer bushing is "oil-lite" type sintered bronze material. The porous metal bushing weeps out oil from its pores with the introduction of a bit of heat. The oiler above is intended to re-supply the oil-lite material. You won't have to oil it very much or even very often, but it is intentional and necessary.
My $.02
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
Bruce L
10-18-2003 10:43:59
 Re: Re: JD 50 brake question in reply to F-I-T, 10-18-2003 09:56:23
Thanks for your comment Frank. I had thought of that although the bushing certainly looks to be very "solid". There is no oil seal used on the shaft, just a dust seal. So a hole through the bushing would probably contaminate the brakes with oil.
F-I-T
10-18-2003 13:22:53
 Re: Re: Re: JD 50 brake question in reply to Bruce L, 10-18-2003 10:43:59
Bruce:
Yes, I think so.
The oil-lite material indeed looks very solid, and it is. I just pressed one into the front pedestal unit on Case VAC and you would have to know it to tell it from solid metal.
If I remember right, the inner brake shaft bushing has hole and it gets oil trickled down on it from gear oil that is sloshed on a drilled hole from above. Truth is, if that outer bushing was greased a bit the last time it was out, it would run all right for years if you didn't get the brakes really hot. After plowing, I would look for the brake drums with the paint burned off, and check those brakes. They'd always need something, if not just cleaned and lubed.
Frank
