H intake valve blow back
Jon
09-30-2002 10:15:46
I have a completely rebuilt 39 H that is hard to hand start after it has been running a while. There is blow back through the intake valves through the air cleaner. If the governor timing was one tooth off, would this cause blow back?
Paul from MI
10-01-2002 19:46:08
 Re: H intake valve blow back in reply to Jon, 09-30-2002 10:15:46
Check your timing using the marks on the flywheel. With the rocker arm clearance set correctly, the L.H. exhaust valve should just start to open when rhe "L.H. Exhaust" flywheel mark is in line with the mark on the main case. If so, the camshaft is timed right. If not, you know what to do. Good Luck, Paul
Dave Thuesen
09-30-2002 18:38:12
Jon,
It sounds like you have a intake valve set to tight. Turn each cyclinder up to top dead center and make sure your vave clearaces are at .020 inch.
Dave Thuesen
