JD 730 crankcase bearings wanted
menno
09-30-2002 03:40:47
I'm looking for the main bearings off the cankcase off a JD730. It has to be the orriginal size.
Thanks Menno
Nathaniel Watts
10-01-2002 07:10:15
 Re: JD 730 crankcase bearings wanted in reply to menno, 09-30-2002 03:40:47
They list for $91.22 each and need .0055-.0075 clearance.
menno
10-02-2002 23:44:22
 Re: Re: JD 730 crankcase bearings wanted in reply to Nathaniel Watts, 10-01-2002 07:10:15
Thanks for the reaction.
The question is now Where can I buy them ???
Menno from Holland
Gpower
09-30-2002 16:19:40
You can get them thru Deere. They are a one piece bearing, you have to have them sized in the housings to fit the crank. Good luck
Gpower
Nathaniel Watts
09-30-2002 10:04:11
Try Albert at Rennaisance Tractor, I'm not sure of the e-mail, but someone else here should know.
