Belt Pulley Removal
Don
09-28-2002 07:55:24
I need to remove the belt pulley from a 1948 B, to grease the bearing, etc. Is there any special knack to this, or anything I should pay special attention to? Thank you.
Don
09-28-2002 18:43:29
 Re: Belt Pulley Removal in reply to Don, 09-28-2002 07:55:24
Thanks for the help. This is the information I was wanting.
Don
Ron
09-28-2002 09:50:04
The rear wheel MUST be set out wide enough to allow removal of the clutch drum, before you start.!!!! I would say--at least 12" from the clutch cover..... You will dis-mantle the clutch--from starting at the clutch cover, remove the 3 nuts, then the clutch parts...until you can not get anything else out..... Then, you will have to use a puller ( or fashion your own ) and pull the driven disc loose from the crankshaft... remove it, and then the last clutch plate..... .. Then, take the clutch lever linkage loose from the clutch fork assembly ( right under the Mag ) and take out the 4 bolts that hold the clutch fork assembly in place at the front of the clutch... Remove the fork assembly ( it just pulls straight out ).... The clutch drum will slip right out ( clean the crankshaft before you slide it out ).... NOW----IF the rear wheel is set out wide enough, the clutch drum will come right off..... If the clutch bolts need replaced, do it now..!!
F-I-T
09-28-2002 11:25:08
 Re: Re: Belt Pulley Removal in reply to Ron, 09-28-2002 09:50:04
It's a been a l-o-n-g time since I had a "B" clutch apart, but aren't there slots in the clutch driver to accept square-nutted bolts to created a pulling system ? Pretty sure the '48 "A" was that way. If so, you just need to find the appropriate bolts and nuts, and you won't risk breaking that driver with a puller.
If my memory is weak, I apologise in advance.
Frank-in-Tallahassee
70D // 855
Ron
09-30-2002 16:22:50
 Re: Re: Re: Belt Pulley Removal in reply to F-I-T, 09-28-2002 11:25:08
My Late ( 1952 ) "B" has two threaded bolt holes for pulling the inner driver.... I use a 1/2" plate with holes for the two bolts, take the washer off the retaining bolt, tighten the plate over the center bolt, and hit it with a hammer...it jumps right off...!! My "60" has the square slots, like your "A"...
