2 cyl firing sequence
Lynn Kasdorf
12-24-2003 07:27:51
JD newbie question here: on 2 cyl JD's, I seem to recall that the 2 cylinders fire at the same time, or maybe one slightly before the other. Is this true? The intuitive thing would be that the firing are evenly interleaved.
Also, what about 2 cyl harley davidson engines?
In either case, if they do fire at the same time, why is this a good design?
(looking for answers for relatives during Christmas conversations)
Happy Christmas, Y'all
Clooney
12-24-2003 08:09:36
 Re: 2 cyl firing sequence in reply to Lynn Kasdorf, 12-24-2003 07:27:51
Lynn, the 2-cylinder Deere's have a 180� crankshaft.. So that means the engine fires one cylinder [the L/H one] first then 180� later the second cylinder fires [the R/H], then there is a 540� coast time before the L/H cylinder fires again.. That 180 � crank lay out is basically used as it is very difficult to balance a 360� crank lay out using large parts.. The 360� crank works good in smaller engines though.. The up side of the 180� layout is engine balance & torque. The downside is cylinder breathing & uneven firing..
~Now on the Harley Davidson there is similar set up but that uses a V type engine instead of a flat engine so that uses a set-up that fires one piston first, then the next piston fires at 315� later, then there is a 405� coast time, then the first piston fires again. That is what gives the Harley that unique sound.. Another difference is the Harley uses a common crank journal for both rods as opposed to the Deere 180� crank.....
MERRY CHRISTMAS
[email protected]
John T
12-24-2003 08:04:09
Lynn, the 2 cylinder horizontal Deere pistons are 180 opposed, one is down/back while the other is up/forward. The 2 rod throws on the common crankshaft are 180 opposite from each other.
The firing sequence is the number one left piston fires at Top Dead Center (TDC) on its Compression Power Stroke, and then 180 degrees of crankshaft rotation later, the other number 2 right cylinder fires on its Compression Power Stroke TDC. Then theres a 540 degree coast cycle before the left number one is back at TDC and fires again. (2 revolution 720 degree 4 cycle operation)
Now, Im not a Harley owner so they can correct me if Im wrong, but I think they have both pistons/rods on a single common crank throw. However, due to the the twin V block design, the first piston reaches its TDC just before the second. I think thats why they make that classic "potato potato potato potato" sound we all love. FORGIVE ME HARLEY GUYS and set us all straight as to how they fire????? ???
Merry Christmans n God Bless yall
John T (2 cylinder guy but NOT a Harley owner)
Lynn Kasdorf
12-24-2003 07:53:56
After I posted, I searched and found a discussion of this topic. Seems like the uneven firing has to be that way, given the configuration of the cylinders.
And, to give us the cool sound!
Thanks
