730 PTO indicator rod length ??
mike in new mex
10-18-2003 06:50:19
Hello- I need the total length of the adjustment rod indicator because mine is broken and Deere no longer sells them and I think I can make one if I had the total length. Thanks-mike
mike-nm--- Thanks
10-19-2003 19:26:27
 Re: 730 PTO indicator rod length ?? in reply to mike in new mexico, 10-18-2003 06:50:19
EOM
MIKE HANLEY
10-18-2003 20:26:09
Why don't you try one of the junk yards for a used one.? Most of them will call around to try and lowcate the part you need. It helps if you have a part book or at least a part number as they all work out of a JD parts book. Start with 513-423-4000. Reg hours central standard time.
F-I-T
10-18-2003 21:03:20
 Re: Re: 730 PTO indicator rod length ?? in reply to MIKE HANLEY, 10-18-2003 20:26:09
If it might help, the part number of the indicator is: F 3402 R, "Indicator, Clutch adjustment".
Frank
