Cultivator mounting about to stump me
Here I am I'm s
09-26-2002 11:58:06
Before you guys jump on me about a manual local dealer no help in getting one [partly because I don't know model #].I need a little help in mounting a hand lift cultivator on a 35 B .I have the front cultivators mounted on front and the ones mounted on the rear I can figure out the rod that does the lifting of the front gangs,problem is isn't the lever supposed to lift the rear also .I don't see any way to fasten the rear gangs to this long rog. The only thing on the rear gang to attach with is 3 small chains .Do these fasten to the rod somehow or am I missing a bracket or two?I have 2 lift levers mounted .Should one lift one side and part of the rear and the other one the other side and the rest of the rear .This is getting to be a challenge to mount these ,but what the heck Ihave until next spring to get ready to play with them .
Will P
09-26-2002 20:02:09
 Re: cultivator mounting about to stump me in reply to Here I am I'm stumped again., 09-26-2002 11:58:06
Email me and I can send you pictures of how hand lift culivators mount on your tractor. I have a 43B with hand lift.
Will P
DP
09-26-2002 13:19:21
This mightt be a dumb question, but does your tractor have factory power lift with the rockshafts? There should be a couple lift arms that attach to the rockshaft.Your chains attach to these, and so do the lift tubes. The levers you are refering to are used to set the working depth.
