John Deere B Timing
Dave
09-26-2002 11:55:02
How do you time a john deere B when the mark on the crank shft gear is missing ?
Gman
09-29-2002 17:23:51
 Re: John Deere B Timing in reply to Dave, 09-26-2002 11:55:02
Dave check with Deere and see if they still supply the gear,it is keyed on shaft and the new gear should be punch marked. another way would be to take another crank and gear assembly(same crank part number)and try to match the mark up.Clooney or WTW might know of another way,this is about all I can come up with at this time. Gman
Ralph
08-03-2004 11:27:34
 Re: Re: John Deere B Timing in reply to Gman, 09-29-2002 17:23:51
I'm having the same problem!
Tore a 39 b down to the bare case, and am now putting it back together,,
Cam shaft gear is punch marked, but no mark on crank gear. Crank is from another B, but original is not marked, and I have another crank from a parts B that isn't marked either.
I guess there must be an answer, but I"m stumped!!!!!
Can anyone out there help????? ???
