Clooney R/H Main Bearing Oil Seal
Aaron
09-24-2002 19:18:28
hi Cloooney, If you remember last week i started tearing into my 730 that was leaking motor oil into the transmission. I forget how you told me to get the seal out. I have everything off just cant remember what i needed to get it out.
Thanks Aaron
Clooney
09-25-2002 08:36:53
 Re: Clooney R/H Main Bearing Oil Seal in reply to Aaron, 09-24-2002 19:18:28
Aaron, I use a dent puller [slide hammer with a screw on the end].
~When installing the new seals make sure you don't drive them in too far & block off the oil drain back hole or you will still have a leak.
