Roll-O-Matic
jose
09-23-2002 15:44:43
that it is Roll-O-Matic? thanks
CJDave
09-23-2002 18:09:21
 Re: Roll-O-Matic in reply to jose, 09-23-2002 15:44:43
Joe.....the Roll-O-Matic front end is a two wheels-together type where instead of just having a spindle sticking out on each side whith a wheel on it, they have little offset spindle arms on each side which are geared together inside the casting so that when one wheel climbs up on a rock the other wheel goes down the same amount giving the tractor sort of an "articulating" front suspension. The only place they aren't so good is in deep mud because one wheel can go Wayyy down as the other rises. Hope this helps..... .Dave
CJDave
09-23-2002 18:07:22
Joe.....the Roll-O-Matic front end is a two wheels-together type where instead of just havig a spindle sticking out on each side whith a wheel on it, they have little offset spindle arms which are geared together inside the casting so that when one wheel climbs up on a rock the other wheel goes down the same amount giving the tractor sort of a "floating" front suspension. The only place they aren't so good is in deep mud because one wheel can go Wayyy down as the other rises. Hope this helps..... .Dave
jose
09-23-2002 18:20:16
 Re: Re: Roll-O-Matic in reply to CJDave, 09-23-2002 18:07:22
CJDave thanks for your aid
