JD1010 clutch brake
Dave
09-23-2002 14:40:46
I was going to buy a JD1010. It had been used ing the spring and had no problems. Went to move it around back to load on the trailer and the clutch brake on the left side quit working. Nothing there at at all in forward but everything is working okay in reverse. Any ideas? Dave
Loren
09-23-2002 15:18:21
 Re: JD1010 clutch brake in reply to Dave, 09-23-2002 14:40:46
A real 1010 question!!! We don't see them here very often. I have a 1010 but you have me confused with your question. There is a brake for each side but I don't know what that has to do with the clutch. The handle on the left side is for the PTO. The clutch pedal is on the left side but that has nothing to do with the brakes. If you need to know about the insides of the brakes, I can give you all kinds of details because I just went through mine. If it is a clutch problem you have, that can be adjusted through a hole in the left side of the main casing. Throw me a few more details of what you are seeing and maybe I can catch on well enough to offer some help.
Dave
09-23-2002 16:48:00
 Re: Re: JD1010 clutch brake in reply to Loren, 09-23-2002 15:18:21
Loren, sorry and thanks for your reply. Try this.
I have a JD 1010. The steering clutch on the left side does not work in forward gear but works fine in reverse gear. When you pull back on the lever nothing happens when in forward gear, the clutch brake does not even come on when pulled right back. Can anyone suggest anything? Dave
Frank m.
09-23-2002 18:23:17
 Re: Re: Re: JD1010 clutch brake in reply to Dave, 09-23-2002 16:48:00
It's a crawler right? Wish I could help but I know nothing about them. At least now your question makes sense. Maybe some of the crawler experts can put you on the right track. Pun intended. LOL
If you can't get an answer here try the crawler board. Good luck with it.
Frank M.
john
09-25-2002 00:12:46
 Re: Re: Re: Re: JD1010 clutch brake in reply to Frank m., 09-23-2002 18:23:17
I am buying a 61' Diesel 1010RS w/ dual PTO, and needs brakes on one side. What am I in for? And while we are on the subject what about rebuilding the leaking pto quadrant?
Loren
09-24-2002 06:09:05
Frank, you have to be right that we are talking about a crawler here. No wonder I couldn't figure it out the first time! Mine is a 1010 row-crop utility so has no similarity to Dave's tractor. I guess I can't be of help after all.
Dave
09-24-2002 21:16:08
 Re: Re: Re: Re: Re: JD1010 clutch brake in reply to Loren, 09-24-2002 06:09:05
Thank you fellows, yes it is a JD 1010 crawler.
As I learn a little more I should have refered to it as a steering clutch. Left side not working in forward gear. Works fine in reverse. Any one with ideas as to why, greatly appreciated.
Dave
tubba_JD420C_ny
09-25-2002 16:13:54
 Re: Re: Re: Re: Re: Re: JD1010 clutch brake in reply to Dave, 09-24-2002 21:16:08
Check on the crawler board. Lavoy is a real whiz on JD crawlers and he is often on the board. He has a real first class web site, too, but i forgot the URL, i think it may be jdcrawlers (?). Anyway, try that board, there are a lot of good crawler people on it.
Good Luck!
