Roger, if those head nuts were over torqued [especially more than once] the studs are more than likely stretched.. ~You might have some head warping or stud pulling also. ~Probably the thing to do is remove the head & have it checked for flatness,, then checked for cracks,, then re-surfaced & see how much warpage there is.. If the cylinder head is not too bad than the block is probably in decent shape.. ~Then remove the cylinder studs & use a fine file & remove any raised area at the stud holes.. Then use a straight edge & feeler stock & check the block for flatness.. If it is decent, then install new studs & re-assemble & torque to specs. ~Now on your leak problem.. If your only problem is a water leak at the bottom of the head,, first look for a small crack in that area, then use some stop leak or block sealer in the cooling water [if no water pump you will need to keep the water moving] either by working the tractor or using a small pump between the lower water drain & radiator neck,, or letting the water slowly run into a bucket & re-pouring it into the radiator... Once that stop leak gets into the leak it will probably stop & not bother you again.. If it comes back then you will have to pull it apart for inspection.. MERRY CHRISTMAS [email protected]
