70 Diesel Question
ZIP
09-23-2002 12:22:37
I am very proud of my new tractor. It started great the first few times I tried it, pony & main. I followed the correct starting procedure from the archives and no problem. Just last night and again this morning the pony motor started fine, like before, but the main diesel engine wouldn't fire and take off on it's own. I tried different combinations of revolutions and throttle settings, but nothing. Can you please help out a new JD guy? thanks P.S. Pulled started it and ran good, but defeats the purpose. thanks ZIP
JDGnut
09-24-2002 11:24:05
 Re: 70 Diesel Question in reply to ZIP, 09-23-2002 12:22:37
Check your fuel pressure from the tranfer pump (this is hard to do when the tractor won't run, but if it will start when U pull it, check the pressure then.) You could have plugged filters or a bad spring in the relief.. or just a leak pump.
Good Luck
JDGnut
G-MAN
09-23-2002 13:42:04
Zip, I am far from a two-cylinder diesel expert, but one thing comes to mind. Is your compression release closing completely when you try to start it with the pony, or could it be hanging up and not allowing the diesel to build compression? If you're pull starting it under compression and it fires right up, that could be the problem. Otherwise I don't know why it would start by pulling and not by cranking. My two cents.
