J.D. 620 L.P. waterpipe
Bill G.
12-23-2003 19:54:04
The metal waterpipe on my 620 L.P. has rusted through, my J.D. dealer says a new one is not available, so is there a source for a replacement pipe? Can I find a pipe with the right O.D. to replace the rusted one?
Bill G.
12-26-2003 20:36:35
 Re: J.D. 620 L.P. waterpipe in reply to Bill G., 12-23-2003 19:54:04
Had some good luck late Christmas eve , found a piece of driveshaft tubing the right diameter ,cut it with tubing cutter, and forced it into new o-rings , not a leak yet ! Thanks for the help.
Mike M
12-24-2003 07:36:05
I would try K & K antique tractors they have some of the odd ball size JD tubing. I don't have there # handy.
CARL
12-24-2003 06:16:37
I HAVE TOP WATER PIPE FOR 730LP WONDER IF IT WILL WORK
JDLPSTD
12-24-2003 06:35:40
 Re: Re: J.D. 620 L.P. waterpipe in reply to CARL, 12-24-2003 06:16:37
I have not replace one on a 620, but have for a couple of 520's. After I had tried all of the pipe and tube places in town, I went to a muffler shop. They had the exact diameter in the same wall thickness. To top it off, if they cut it with a pipe cutter, it rolls the ends down slightly and makes them easy to get into the O-rings. I would try a couple. Good luck.
