John Deere 50
Reasonable Offer
Little Laurel
09-21-2002 05:46:18
List,
I found an abandoned JD 50. I know the owner of the property and was wondering what a 'reasonable' offer would be. It is rough, and I expect it would take a LOT of work to just get it running. There is quite a bit of surface rust, but it is restorable.
On that note, what should I look out for (missing parts, etc.) which would be difficult to locate.
I know this is a vague question, but I am just trying to figure out whether I want to haul the machinery out.
John Van
09-23-2002 16:35:51
 Re: John Deere 50 - Reasonable Offer in reply to Little Laurel, 09-21-2002 05:46:18
I just bought a 50 myself but it's in VERY nice condition. Paid $2400. You really can't tell much about yours except that it was abandonded. There is a reason for that. Additionally mother nature has taken a toll on whats left. I would first offer to haul it off. If you plan on getting it running it's likely to cost more to fix it up than it will be worth when you are done. Nothing wrong with that as long as you start the project with your eyes open.
I would not go any higher than $100. It's worth that much for parts but I look at it this way, a running tractor is a lot more fun than a garage full of parts.
Best of luck,
John
Willy
09-23-2002 04:40:20
check where the drawbar frame bolts to the bottom of the rear axle housing the 50's liked to crack around the bolt holes. and remember some one has to save these old tractors if we part out everyone that is setting in the weeds one day we will have a whole lot of parts to put on a tractor that is gone. good luck! Willy
mike
09-21-2002 15:00:36
If you got it for free it still might be to high.
Good ones don't sell very high.I would probably
take it to an auction with a dead row and just
sell it.
Ben.So.Tex
09-21-2002 07:11:48
What can the owner tell you about the tractor? How long has been setting?Last time it ran?Is it froze up? What shape are the tires/radiator in. Look to see if the drain plug was removed and check the bottom of the head, this is where they like to break if the water was left in the tractor, is there still fuel in the tank, has it varnished, rust in tank, (possible gummed up carb),These are thing I look at/for,,,(good running 50, $1200. Parked $250./300.) My 2 pennies. GOOD LUCK.
Muffler Bearing
09-21-2002 18:09:59
 Re: Re: John Deere 50 - Reasonable Offer in reply to Ben.So.Tex, 09-21-2002 07:11:48
I bought one like this- should of left it in the weeds. I got 4,500.00 in an old 38 A. Still needs a few things.
