Tye: That is a COPY of a picture on my web site as noted below: Here is some info on Be Ge that I received from John Boehm on this unit: What you are looking at is a BeGe aftermarket control valve unit. BeGe was located in Gilroy, CA and made top quality aftermarket hydraulic units for a wide range of tractors, before the manufacturers came out with their own improved hydraulics. They are most often seen in California on Caterpillars and almost every old farm Cat had a unit. They are much less common on Deeres. The control valve for A-B-G that took the place of the regular powerlift control valve had the long horizontal handle that you see in the photos. BeGe was bought by Oliver Corp in the early 1950's. After the White era, etc. with Oliver being bought out, the remaining inventory of parts for BeGe ended up at Associated Tractor, a wrecking yard in Stockton, CA and they still have some NOS parts available. BeGe also made scrapers and land leveling equipment. I have several old parts catalogs and other literature from the company before and after the Oliver buyout. I also have several A's and B's with the same BeGe unit that you saw and also one with a two cylinder valve for the Model D. I recently sold one of the A valves and the D unit to Greg Stephen. These units were originally painted Caterpillar yellow, even when they were installed on other makes, including Deere. Whoever restored the tractor you saw took the liberty of painting it green and adding the decals-they do not belong on the unit. John Boehm
