G Throttle Linkage
Brandon
09-18-2002 14:43:41
What is the general rule for setting the throttle linkage on a John Deere. I think somebody said that the throttle linkage needs to be half a hole short of the throttle shaft on the carbuerator with it at full throttle. Is this right? Do I need to have the tractor running and turn it off with it at full throttle, or can I push the throttle up with it off and be accurate? Thanks for the info.
Brandon
Big Kendal
09-18-2002 19:20:25
 Re: G Throttle Linkage in reply to Brandon, 09-18-2002 14:43:41
Best do it with engine stopped.
Mike Aylward
09-18-2002 17:02:35
Brandon, the adjusting is done with the engine off. The "half a hole short" is the factory recommended setting but I set all of mine a full hole short and they are much more snappy and throttle responsive. Once this adjustment is made it need never be bothered again unless the carburetor, manifold or something connected is removed and reinstalled. Hope this helps. Mike
BJ
09-18-2002 16:50:07
If I remember right leave the motor SHUT OFF pull the throttle handle wide open and also pull the throttle in the carb. wide open and then adjust the governor to carb rod a half a hole short. Later
SEAMO
09-18-2002 16:44:52
ENGINE OFF!!!!!
