Backfiring diesel...
kevin
09-18-2002 09:40:46
I have a neighbor who got a basket case 4630 at an auction and put it together and the engine backfires and runs rough..where to start ??
G-MAN
09-18-2002 10:42:11
 Re: backfiring diesel... in reply to kevin, 09-18-2002 09:40:46
Was the engine apart? Make sure the fuel shut-off is allowing the pump to get full fuel. Make sure you're getting a good supply of fuel to the pump and that the filter is clean. Then I would check pump timing. After that, I would look into pulling the nozzles and checking them, along with performing a compression check while they're out. If you still have problems, check cam/crank timing. You could probably do this by pulling the valve cover and checking for split overlap at #6 cylinder when the timing pin drops into the flywheel at #1 TDC compression. If that seems to be off, I would pull the front cover and check the timing marks first hand. Also check that the engine hasn't sheared the cam or crank gear keys, although this is pretty rare. Checking and adjusting the valve lash while the cover is off is also a good idea. One of these things is probably the problem, and I would definitely get ahold of a service manual before tearing into it.
kevin
09-19-2002 09:25:37
 Re: Re: backfiring diesel... in reply to G-MAN, 09-18-2002 10:42:11
he put a big bosch pump on it that was in the box 'o stuff that came with it. the owner died and he put the engine together. he gives it a small amount (just a continuous whiff) of ether in the air intake and the engine really smooths out and runs great then when stopping giving it ether it runs rough again and backfires flames right out the exhaust. probably should take the pump off and send it out to be gone thru? thanks
