4/5 HIGH SPEED TRANS OPTIONS
plowin
09-17-2002 09:44:17
What was the main use for this trans option?What gears run faster ground speeds all or just some? Where can I get info on this trans is it covered in the operators manual.Sorry folks new to the two cyl tractors,and I'm finding out there is a lot to learn.Thanks in advance.
plowin
Clooney
09-17-2002 15:23:08
 Re: 4/5 HIGH SPEED TRANS OPTIONS in reply to plowin, 09-17-2002 09:44:17
plowin, are we still talking about the 720?
~If so there was an 8 MPH 5th gear offered as well as a 4-3/4 MPH 4th & 12-1/4 MPH 6th. The shift quadrant is different & if an early 720 the sliding gear shaft is different.
~I really can't tell you what those gear speeds were for but the 8 MPH 5th is perfect for pulling a loaded wagon, or transporting with a load on the 3-point, & the slightly faster 6th will get you around 15 MPH at high idle with 15.5 tires.....
plowin
09-17-2002 16:47:53
 Re: Re: 4/5 HIGH SPEED TRANS OPTIONS in reply to Clooney, 09-17-2002 15:23:08
clooney yes that 720. I bought it haven't got it home yet was wondering what I have.Thanks for the answer I'll try to keep the stuppid ?s to a min.
Thanks Plowin
Clooney
09-17-2002 16:57:00
 Re: Re: Re: 4/5 HIGH SPEED TRANS OPTIONS in reply to plowin, 09-17-2002 16:47:53
plowin, there not stupid questions if you don't know the answer & need to find out about something.
~You will find this board very knowledgeable & helpful with most of your 2-cylinder questions....
