2020 problems
M Hutch
12-23-2003 14:48:07
I have recently purchased a 2020 gas. It cut off on me the other day. I'm getting fuel to the carb and fire at the plug. While checking the carb I broke the shut off silenoid. New one has a wire. My questions are, where does the wire go from the silenoid, and what else should I look for to get it to start?
Thanks
Larry B.
12-23-2003 17:19:10
 Re: 2020 problems in reply to M Hutch, 12-23-2003 14:48:07
That fuel shut of soloinod is a persnicikety critter. Mine has been replaced with a new one but still sticks occasionally. I give it a rap with my pocket knife between cranks and that usually fires the old girl up. Once in a while when she's running she will fuel starve and the old rap along the side of the soloniod fixes it every time. I had the same problem with two of them. Someone told me that you can order a regular fuel jet to go in the same hole in the carb to adjust load without the electric nonsence but when I ordered one it did not fit my carb. Incidently just to confuse things mother deere made the tractor 12vdc, the fuel soloniod 12vdc and the coil and primary ignition 6vdc. Lots of these older tractors haver been rewired and if any voltages are misapplyed she will not perform right. Good luck
