730 PTO Seal
Aaron
09-16-2002 18:15:56
Hi, I have posted a few times about my 730diesel losing oil into the transmission. I am sure that the oil is going through on the right side of the tractor and im sure it is The PTo seal that is bad cause when i use the pto the oil level drops really fast. My question is what all has to come off to fix that seal? Thanks Aaron
Clooney
09-16-2002 18:24:31
 Re: 730 PTO Seal in reply to Aaron, 09-16-2002 18:15:56
Aaron, are you just talking about the PTO oil level dropping or the engine oil also? If just PTO oil then the PTO input shaft seal(s) are probably leaking & the back of the tractor will have to come off.
~If you are also losing engine oil then you probably have a leaking R/H crankshaft seal. To replace that, the clutch, 1st reduction cover, PTO idler gear, PTO drive gear, R/H brake, 1st reduction gear will have to come off & the seal pulled with a dent puller or the R/H main bearing housing will also have to be removed.
Aaron
09-16-2002 18:28:09
 Re: Re: 730 PTO Seal in reply to Clooney, 09-16-2002 18:24:31
Clooney, The motor oil is dropping. The oil in the pto housing is fine. Also what is a Dent Puller?
Thanks Aaron
Clooney
09-16-2002 18:44:32
 Re: Re: Re: 730 PTO Seal in reply to Aaron, 09-16-2002 18:28:09
Aaron, a dent puller is basically a slide hammer with a sheetmetal screw on the end of it. You screw the dent puller screw into the seal & use the slide hammer to hopefully pull the seal out of the housing. ~You will also need a BIG long gear puller to get the PTO drive gear off the crank. That gear is pressed on with a lot of force.
~If you don't already have one I would suggest a Deere repair manual, or an I&T JD-201 book. If you aren't familiar with that seal replacement it is easy to damage expensive parts during the removal process.....
Aaron
09-16-2002 18:51:14
 Re: Re: Re: Re: 730 PTO Seal in reply to Clooney, 09-16-2002 18:44:32
Thanks Clooney, I do have the manual for the late 720's and it is the same for the 730. I will be tearing into it tommorrow night. Ill let you know how i make out.
Thanks Aaron
