JD 300B fuel injection woes
Denny Key
09-16-2002 17:50:03
After many problems with injector pumps and the timing of same, I finally got my tractor to run, now it runs wide open, and will not idle. Any Ideas out there?
Jonathan
09-17-2002 14:28:56
 Re: JD 300B fuel injection woes in reply to Denny Key, 09-16-2002 17:50:03
Was the pump rebuilt and now you have this problem ?? The throttle lever is coupled to the mechanical throttle lever on the pump with a spring configuration...check that it moves freely back and forth..(disconnect the linkage rod)and move it back and forth by hand... If it only runs at wide open throttle with the rod disconnected and the lever all the way forward(I believe its forward) , then there is a problem with the pump . If it was just rebuilt, I'd bring it back to whoever did the work...
