3010 leaking a lot of transmission fluid by lower 3pt mount?
Scott Trautman
09-16-2002 16:32:53
Just recently bought my 3010D. Guess it got by me that this gal leaks a lot of transmission fluid, I bet almost a quart every other day even. Too much to ignore.
In scooting under the back end, it's wicking off to the lowest point, where the bottom of the 3pt hitch mounts, mostly on the left side. Some coming out of PTO, but that's fairly minimal.
So, ideas as to what's leaking? I do hope it's going to be "sure you can do that yourself...."
Axle to transmission case gasket? If it were that, is that something I could do myself? Or how much is this going to set me back at the dealer....I've got some gunk to powerwash off still, but at that angle, I'm gonna get a faceful!
Thanks for any tips!
Scott
Larry
09-17-2002 09:03:31
 Re: 3010 leaking a lot of transmission fluid by lower 3pt mount? in reply to Scott Trautman, 09-16-2002 16:32:53
I bought the updated bushings with o-ring from John Deere - $14.95 each. They get them from A&I. I used them, but had to clean out metal chips and debri from the o-ring groove and the o-rings supplied were too large for the groove. We have an o-ring kit so I found the correct size and being Sunday we went ahead and made them work. I let the dealer know about the quality of the parts, but don't know if they passed it on to their supplier.
Craig-MN
09-17-2002 08:04:41
Yep, load shaft seals like the other guy said.
Thought I read somewhere on this forum that someone had some new style parts available for that? There is a local shop here in MN that has a machine shop cut a groove for an oring in the new load shaft bushings. Supposed to help eliminate that leak forever.
Ducknose Bob
09-16-2002 16:53:51
Loadshaft seals, common problem. While you have the oil drained check the sump screen, and run a magnet inside the trough to see what has settled out over the years. Good time to replace the hydralic oil and filter if it hasn't been done in a while.
JIM MALLANEY
08-27-2003 18:19:51
 Re: Re: 3010 leaking a lot of transmission fluid b in reply to Ducknose Bob, 09-16-2002 16:53:51
i have same problem on my 4010 how do you get to the oil seals to replace them does anyone have ideas.please let me know. thanks
