Carb Rebuild Question
KrisA
09-16-2002 08:08:35
When rebuilding the carb can you get a new cap that is on the bottom of the throttle plate rod? One was not included in the rebuild kit so i was just wondering. Or is there a way to get it out in order to reuse it? Thank you very much and hope everyone has a great week.
KrisA
WTW
09-16-2002 10:18:16
 Re: Carb Rebuild Question in reply to KrisA, 09-16-2002 08:08:35
Kris, They are availble at your JD dealer. They are not part of the kit. I replace them on a regular basis when replacing throttle shaft bushings.
KrisA
09-16-2002 13:48:56
 Re: Re: Carb Rebuild Question in reply to WTW, 09-16-2002 10:18:16
Thank you very much for your input. I greatly appreciate it.
KrisA
Jerry S
09-16-2002 15:19:30
 Re: Re: Re: Carb Rebuild Question in reply to KrisA, 09-16-2002 13:48:56
Another source might be robertscarbrepair.com
Mike
09-16-2002 20:31:12
 Re: Re: Re: Re: Carb Rebuild Question in reply to Jerry S, 09-16-2002 15:19:30
What is a good solution to clean a carb taken off the two-cylinder? I have used gasoline but their must be something better?? Thanks
KrisA
09-17-2002 05:35:32
 Re: Re: Re: Re: Re: Carb Rebuild Question in reply to Mike, 09-16-2002 20:31:12
I am using a parts washer and a little elbow grease mixed with TLC. So far that has worked for me. Remember don't rush, you will pay later.
