Cubic inch
Kemper
09-16-2002 06:12:00
Can someone give me the formula to calcuate the cubic inches of a engine?
CJDave
09-16-2002 14:58:51
 Re: Cubic inch in reply to Kemper, 09-16-2002 06:12:00
Leon has nailed it for you. Those of us who spend a lot of time figuring the volume of circular containers know that a square multiplied by .7854 becomes a circle. So taking Leon's lead here, the bare formula is : Bore X Bore X .7854 X Stroke = the number of cubic inches in ONE cylinder. Then multiply by the number of jugs that the engine has. You need to express everything decimally of course, like 3.875 not 3-7/8 ..... Dave
kraig WY
09-16-2002 07:08:17
pi r squared, times stroke, times number of cylenteres. or
1/2 bore, squared, times 3.1416 times stroke times number of cylenders
John T (Pi x R squared x Stroke x Cylinder No.)
09-16-2002 07:06:58
Kemper, if you know the bore and stroke heres how you do it. The volume of a cylinder in cubic inches is equal to the area times the height, so its Pi (3.1416) x Radius (1/2 of bore) squared x height x number of cylinders. Pi x R x R x Stroke x Cylinder No. So if the bore were 4 and the stroke 6 and you had 2 cylinders, the Cubic Inch is 3.1416 x 2 x 2 x 6 x 2 Cylinders. Clear as mud????? Ol John T Nordhoff in Indiana
Stan - Florida
09-18-2002 15:35:04
 Re: Re: Cubic inch in reply to John T (Pi x R squared x Stroke x Cylinder No.), 09-16-2002 07:06:58
John,
That's what I was trying to say, but I'm not good at explaining things without getting too complicated.
You (us) Hoosiers are a good bunch, though.
STan
Stan - Florida
09-16-2002 06:43:25
Contact me by e-mail and I can help you. I'll need to know the bore, stroke and number of cylinders. It's easier for me to tell you the CID than to explain how to calculate it.
Maybe someone else on here can explain things simpler than I can, but I do have a little Lotus spreadsheet set up to instantly calculate CID, so it's easy to give you your answer.
Good luck,
Stan
Handsome Jim
09-16-2002 17:05:27
 Re: Re: Cubic inch in reply to Stan - Florida, 09-16-2002 06:43:25
You must be a new comer to this group. Welcome aboard Kid.HJ
leon
09-16-2002 07:13:58
In inches, multiply the bore by itself, then multiply by 0.7854, then multiply by the stroke, then multiply by the number of cylinders. For example a two cylinder engine with 4" bore and 5" stroke: 4 X 4 X 0.7854 X 5 X 2 =125.664 cu in.
