Electric help
Ira Biggs
09-15-2002 18:24:13
I have a 1944 JD A After i jump start it it runs great till i pull the jumper cables off. Then it just plain dies on me. Any help will be great thanks
Mike in Mo
09-15-2002 18:50:28
 Re: Electric help in reply to Ira Biggs, 09-15-2002 18:24:13
I assume you have a distributer, if there is no/very low charge in the tractor battery there will be no power to the ignition system. If the battery is charged check for bad connections at the battery. Mike
Clooney
09-15-2002 18:49:20
Ira, it sounds like a dead battery to start with then the generator isn't working after it starts.
~Does the ammeter show a charge when running? If not you have charging system problems.
~Try charging the battery then see if it will stay running....
