300b Charging Problem
Brian
12-23-2003 09:41:21
Hi All, I hope that someone can help. I have been working on a JD 300B for a charging problem. I put on a new alternator and voltage regulator but it still won't charge unless I full field the alternator then it charges at about 17v. The VR is a 4 wire located under the dash and the Alternator is standard 12v with connections for output, ground, field, and regulator. The idiot light on the dash will NOT light up. I cannot find any breaks in the wiring and I have flashed the field and checked grounds at alternator and VR. If anyone has any suggestions, please let me know. Thanks!
Brian
cannonball
12-24-2003 06:28:36
 Re: 300b Charging Problem in reply to Brian, 12-23-2003 09:41:21
i may be wrong but i think the light must burn when key is turned on and if charging will go off..the light is acting as a resistor..i have a shop manual on 300b ...i have not checked if i get time i will...have nice day may god bless
Brian
01-13-2004 13:47:03
 Re: Re: 300b Charging Problem in reply to cannonball, 12-24-2003 06:28:36
Hi again Cannonball. Just thought you might like to know that it turned out to be another bad voltage regulator. Thanks for your input!
Brian
Brian
12-25-2003 07:56:35
Thanks Cannonball, the light does not burn. The ground side is open and the hot side is hot with battery voltage. The light is just paralled in though. I think that the VR is supposed to provide the ground. If you can check the manual when you get time, I would be eternally grateful! Thanks,
Brian
