720 shifter problem
Plowin911
09-14-2002 19:47:05
I went to look at a 720 today as I was going through the gears to check for trans noise when a funny thing happened.When shifter was in the number 3 slot the trans was in fifth gear.So then I put the shifter in the number 5 slot sure enough the trans was in third.No I wasn't drinking I Tried it two or three times even went back to first than back to fifth trans was nice and quiet and shifted smooth.Has anyone ever heard of this?
Clooney
09-15-2002 05:14:58
 Re: 720 shifter problem in reply to Plowin911, 09-14-2002 19:47:05
Plowin911, it sounds like you have the optional 5th or optional 4/5 gear set & the quadrant wasn't changed.
~The 3rd slot would be 5th gear but are you sure on the 5th slot? [it should actually be 4th if you have the optional gear set(s)
~One other way to tell is if 5th [the old 3rd slot is fast [about 8+ MPH].
~Use a yellow grease pencil & re-label the quadrant & see if it fits when you drive it...
~Old 1 is new 2,,,old 2 is new 1,,,old 3 is new 5,,,old 4 is new 3,,,old 5 is new 4,,,old 6 is still 6th & rev is the same.....
plowin
09-15-2002 15:47:23
 Re: Re: 720 shifter problem in reply to Clooney, 09-15-2002 05:14:58
Yes you were right.Thank you and can I ask why this option was offered by JD?Can I find the correct quadrant?Thanks again for your time.
Plowin
