24T baler
Wade
09-14-2002 18:53:01
We have a 24T baler normally working quite well but today the shear pins starting breaking and the needles are not retracting. Any ideas on what the problem is and does anyone know how to time it?
Scott, OR
09-16-2002 12:56:15
 Re: 24T baler in reply to Wade, 09-14-2002 18:53:01
A couple years ago my 214T baler started breaking shear pins and it looked like the needles weren't retracting. Turns out there is a spring loaded cam roller that follows the inboard knotter disk and drops into a notch at the end of the tying cycle, stopping the knotter at the correct position. My follower had broken, allowing the knotter to turn a bit too far. This allowed the needles to come off of the fully retracted position, the needle stop dogs to enter the bale case, and the shear pin to break.
Of course there are a lot of other things that could go wrong, but you might want to look for that cam follower.
Hope this helps.
Scott
Jim B
09-15-2002 05:05:35
Wade,the needles are operated by a chain on right hand side of knotter at top if it is like a 214 and I think it is.Be sure chain is not broken.It also has shear pin on needle lift shaft so if needles hit something it won't break or bend needles.Check that shear pin as that pulls needles into and out of bale chamber.Also on needle drive chain it should be hidden under a shield,if chain is broken needles will have to be timed to plungerhead.If you don't have a manual it will be hard for you to time.I hope this helps not many 14T balers around back when I worked on sq. balers.Jim B
