Generator connection JD R
me
09-13-2002 12:37:42
Who knows the connection from battery to regulator to generator off a JD R
Thanks
Clooney
09-13-2002 16:01:06
 Re: Generator connection JD R in reply to me, 09-13-2002 12:37:42
Me, [L] on regulator goes to light switch,,,[BAT] on regulator goes to ammeter [non-battery side],,,[F] on regulator goes to [FLD] on generator,,,[GEN] on regulator goes to [ARM] on generator. The other post of the ammeter goes to the big starter post, then to the battery through the battery cable....
~A wire also runs from the [F] post on generator to a voltage relay & then the other terminal on the voltage relay runs to the hour meter [if you have one].
~If you need a wire diagram? E-Mail me...
