How wide are the 16 front rims on a 620?
Nathan(GA)
09-12-2002 17:31:02
Mine are the 1268R and are cracked around the lug holes. I need to order some after market wheels. How wide should they be? And how big is the center hole? Thanks
gwh
09-13-2002 09:48:08
 Re: How wide are the 16 front rims on a 620? in reply to Nathan(GA), 09-12-2002 17:31:02
Nathan, JD1268R rims are only 4" wide, do you have a loader on this tractor and do you have a wide front end? My 720 had wheel problems(w/loader, wide front) and i went to 15" wheeles from a hay wagon, about 5.5-6" wide, put 7:50X15 tires on and used John Deere lug bolts part # E48097(1.25" long) this allowed me to screw on a 1/2" fine threaded nut on the inside of the hub to help secure the wheel-hub bolt(s). Miller tire has wheeles and tires and a special reinforcement plate for 6 bolt wheeles.
Nathan
09-13-2002 10:39:45
 Re: Re: How wide are the 16 front rims on a 620? in reply to gwh, 09-13-2002 09:48:08
Thanks for the reply gwh. It's just a narrow front and no loader. I bought new 6.00-16 tires and went to mount and noticed the hairline cracks around the lug holes. Farm Bureau has some after market wheels for $31 each. Just need to be sure about width and the center hole.
