Installing bolts on newly painted sheet metal
Paul (ND)
12-23-2003 05:59:28
Any of you guys have any tricks when installing bolts on newly painted sheet metal to prevent the paint from "twisting" off the sheet metal when the bolt is tightened? I am especially referring to bolts that go into tapped holes where you can't tighten the nut and hold the bolt head. On these kind of bolts I am having a real problem with the bolt head (actually the flat washer) "twisting" off the new paint as I tighten the bolt. Thanks.
Jack
12-23-2003 13:17:38
 Re: Installing bolts on newly painted sheet metal in reply to Paul (ND), 12-23-2003 05:59:28
I've had decent luck oiling a small piece of duct tape w/ water soluble lube to use as a 'gasket' between the hex & painted surface. Once tight, rip it out & a wee bit will stay behind for dis-assembly later on. There's no real fool-proof way, unless you put the gloss coat on once the sheetmetal is mounted. I've done this as well, draping & masking off areas not to be sprayed. Sometimes this is the best approach, especially if you 'tweaked' the sheetmetal by block-sanding, welding, etc., as it never seems to line up the way it did before you took it off. In addition, be certain that you don't stretch those pitted & iced hoods too much, or the icing can pop off. Deere hoods aren't near as bad as the $#*!all's!!
Mike M
12-23-2003 07:15:58
That's one reason I don't like to use hardener.
JDBert
12-23-2003 07:01:23
Just had this thought since I'll be installing sheet meatal soon. What would happen if a guy would put vasaline or KY jelly (washes off with water) on the back of the washer. Just a thought
Clooney
12-23-2003 06:42:05
Paul, I know what you are going through as I paint almost all of the sheet metal & small parts off the tractor...There are some tricks to use.. [depends on the situation]
~First I don't use lock washers [I hate those things], I use a small washer that is the same thickness & diameter as the proper lock washer but doesn't have the slit. {I do use a small amount of Loc-Tite on almost every bolt though}
~Most bolts that go on [went on] to hold sheet metal have some type of washer under the bolt head. I have been known to glue that washer down with a dab of trim adhesive. That way the washer wont spin or move around on the sheet metal when tightened.
~In some cases I use a very thin small diameter washer under the bolt head so the bolt can spin but not tear the paint off with the bolt hexations. In some extreme cases on a high visibility areas I will even chuck the bolt in the lathe & back cut the under sides of the bolt hex area so it has a round built in washer under the head [that way the hex area doesn't sink into the paint under it when tightened].
~You just about have to take every point of bolt attachment differently & take precautions on that particular attaching area..
~One thing is to not put the paint on too heavy around the bolt attachment areas.. If you built the paint real thick at the attachment areas you are asking for problems at installation time.
~When all done, go over everything with some touch-up paint & a good small tipped brush..
MERRY CHRISTMAS
[email protected]
Larry (So. Dak.)
12-31-2003 10:07:01
 Re: Re: Installing bolts on newly painted sheet me in reply to Clooney , 12-23-2003 06:42:05
It seems that a �rubber� washer may be a good option. First, the rubber would not damage the sheet metal. Second, the preload acting on the rubber may be sufficient to keep the screw from backing out. A �small� amount of thread locker is an alternate. Finally, a rubber washer may reduce chatter or noise due to the screw-sheet metal contact. I know from experience this aspect is annoying to say the least.
Another point for considering a rubber washer is the flexibility it offers for alignment issues.
Question: Is sheet metal damage a big enough issue to consider building an improved fastening system? My background is in noise, vibration and shock attenuation. I mention this in light of my experience with a Farmall M and 400.
