600-A hicycle only runs if it is fully choked HELP !
Nelson Prochask
09-11-2002 18:00:01
My 600-A hicycle 3 cylinder only runs fully choked it's fouling the plugs. I'v taken the carb. apart and cleaned it, but no help.
FARMER JACK
09-12-2002 09:30:56
 Re: 600-A hicycle only runs if it is fully choked HELP ! in reply to Nelson Prochaska, 09-11-2002 18:00:01
SOUNDS AS THOUGH THE ENGINE IS NOT GETTING ENOUGH FUEL. CHECK THESE AREAS
REPLACE FLOAT VALVE AND SEAT (IF VALVE IS STICKING)
CLEAN (DRILL) OUT PASSAGES WITH PROPER SIZE DRILL BIT(S)
MAKE SURE FLOAT FLOATS AND MOVES FREELY ON PIVOT PIN.
