Dumb John Deere ?
krum
09-11-2002 11:03:42
I just bought a John Deere M with a loader. One of the hydraulic cylinders was leaking so I had it fixed. Now the dumb question. How do I get the ram to extend out so I can connect the ends to the loader? I can lift the loader with the ram that I didnot remove, but I cannot get the ram that I repaired to extend itself. Do I have air in the line? I tried to bleed out the air, but not sure if I was totally successful. Another dumb question. I have not got any manuals for this tractor yet and I'm not sure how to check the hydraulic fluid level. Can someone help me out here please? Thanks for any help, krum.
Ray
09-11-2002 16:07:17
 Re: Dumb John Deere ? in reply to krum, 09-11-2002 11:03:42
Just remove the hose that connects to the cylinder
and pull it out to connect,then hook the hose
back up,work the loader up and down it will
bleed its self.
Danny
09-11-2002 13:37:02
I do not know what the loader you have looks like, but if it has two way cylinders, I think you may have reversed the lines when you hooked it back up. The cylinder with the free end should move first (path of least resistance). If the lines are reversed then one will try to retract as the other extends.
